david lamontagn
01.05.2008, 03:29 PM
Originally Posted by raptor50 View Post
OK,, I dont know why its not working but here what I did.
Im using 2 2S 4000 to make up 1 4S in series.
I did what was told to me and nothing works now.. I took out the red wire from the esc and put that into channel 2, and bec into channel 3. Now, nothing works. Before when I took out the red wire, I put the esc plug on channel 2, and bec on channel 3 plug, and everthing worked except that i didnt know where to put the brake servo wire. When I got the Bec, the cover showed to put the esc into 2, and the bec to 3 w/o any ommission of the red wire in channel 2. When I look into CC website, it shows to take out the red wire in the ESC plug.. Now im confused.. here are the pics..
http://www.rcmonster.com/forum/showthread.php?t=9375
any help is appreicated.. thanks,
Hey!!!!!!!!!!!!! i've tell you to put the BEC in chanel BAT,not in the chanel 3!!!!!!!!!! That's the brake servo that goes in the chanel 3
Take your time and re-read what's i've write for you in my previous post:
Chanel 3 is not for the BEC. Your BEC should plug in the BAT slot of your Rx.
You plug the ESC in chanel 2 (remove the red wire of the ESC signal plug and insulate it if you use an external BEC) and your brake servo plug in chanel 3.
What you ave to do:
Set your ESC to the lowest brake setting, or if you can, cancel the brake in your MM programmation setup.
Now, set your Tx End point adjustment chanel 2, full trottle set at 100% and brake set at 0%.
now, set the chanel 3 End Point, full trottle set at 0% and full brake set at 100%.
Now, (i hope you have the MIXING fonction on you 3PK) mix chanel 2 and 3. Master will be chanel 2 and slave will be chanel 3.
And your link for the pics don't work at all!
