ssspconcepts
ssspconcepts's Avatar
01.05.2008, 11:08 PM
Originally Posted by mustbnitro View Post
I have a True R/C 8000MAH 4s pack, MRC 989 charger, and an astro blinky balancer. I set the MRC 989 to 8000MAH, 8Amp charge and 4 cell Lipo settings. After 20 minutes, the voltage is soaring to 16 volts. Now the Astro blinky balancer has been on it for about 4 hours and it is not balanced yet! To worry me, I have not seen the second cell light come on on the balancer. What could be wrong or am I doing wrong???
I am not familiar with the blinky....but I use the MRC989 with a flightpower balancer and it works like a charm. I've only had one hickup and it was due to a bad deans plug. It sounds like the blinky is a balancer that you use after the battery is charged? The flightpower balancer does its job during charging...seems a lot more reliable and better for the battery to me...
I have also heard good things about the hyperion balancer...it operates almost exactly the same way. Sorry this doesn't answer your question, but if you decide to go out and buy a balancer, atleast you have a recommendation. I'd even post pics on how to hook it up if you want.
