01.06.2008, 10:22 PM
run 2 if you can distribute the weight evenly, or one big one, if you have to put it in one location. check out the apogee li-mn 5800 batteries. they're a little pricy, but well worth it. get 2 2s packs ($300) and wire them in series. OR: you could get 2 2s 3800mah packs, sacrifice a little runtime, but have less weight and save yourself $150. do not use 2 3s in series (too much for the mamba max to handle.) i like li-mn because they dont blow up like lipo, and offer the same performance-to-weight ratio that lipo's do. rc-monster carries the 2s packs of both capacities.
personally, i would sacrifice the runtime and get the 3800's because they're half the price, IIRC, about 100g lighter per pack. here is a link to the 2s 3800 packs
http://www.rc-monster.com/proddetail...P3800MN&cat=18
use the normal li-po mode on your charger, charging procedure is exactly the same as li-po, except for the "blow-upping" part.
i definitely recommend li-mn over li-po and ni-mh because they don't blow up and are lightweight. visit
http://pfmdistribution.com/secure/shop/listcats.asp
for all your battery needs. it sounds like i work there
if you only have enough space for one battery, check this one out:
https://pfmdistribution.com/secure/s...d=254&catid=47
if you are nit farmilliar with li-mn and li-po you will need:
1. li-po charger
2. balancer (for as many cells as you're going to run)
3. fan for your mamba max, (they're not supposed to run 4s, but it usually works fine)
4. LVC (low voltage cutoff)
5. BEC (battery eliminator circuit)
i really hope this helps.
