sikeston34m
sikeston34m's Avatar
01.12.2008, 01:56 PM
Most people seem to find that the 125b does not like a fully charged 6s pack. Once the voltage comes down a little the quark seems to be ok. Since your setup is obviously not drawing a ton of amps, you are most likely not overtaxing the 125b. I havea feeling that the quark is somewhat sensitive to gearing when running on 6s. Too much load and it will most likely have issues, as many have found.
Nice to hear that it is working well for you. If I put the 2826/12 in mine it should run great. Lower kv will load the esc even less, I may be able to get away with a quark 80, instead of the 125b.
Not to hijack your thread, but I just ordered another 125b and a savage ss kit. I also ordered the brushless savage chassis from mike! I may try an out runner in this, as it looks to have some more room, and mech brakes too! alo bought a pair of trakpower gold lipos, a greatplane 60hv esc with prog card, 3 more ccbec, and a sv27 6 pole boat motor to test out. It was an expensive morning! (not really as I have worked a trade with the lhs owner for most of the stuff I got)
Really like the out runner setup you did here sike, looks clean and I am sure that will run well. Are you going to stay with 6s, or step down when the 2 speed comes out? Or are you going for some insane speed!?!
No Worries on hijacking the thread. It's open house as far as I'm concerned. LOL
You're probably right on the 6S experiences/comments. In a setup that was overgeared and cogging. I think it would crash the ESC quickly if a person just kept stabbing the throttle, trying to make it work. Even when it's headed for a thermal shutdown, I feel like the thermistor takes a few seconds to react. If the heat is too drastic and the situation comes about too quick, damage occurs before the thermal shutdown happens.
On the topic of comparing kv ratings of motors. It seems to me it's a trade off. The lower the kv, the higher the torque. But by going to a higher kv, you take some of that torque for rpm making ability. This applies to inrunners and outrunners alike.
More toys huh? Yes, The Quark 80b may work with this just fine. NO temp issues at all with the 125 amp ESC.
I really like what the BEC does to a system. What brand are the ones you got?
The SV27 motor is a screaming, by just looking at the Video's. It's putting out some Omph!
I have a Traxxas Villain EX on the way. Got a good deal on a used one. I've been toying around with the idea of putting 2 - AXI 2820/8's in it. They are 1500kv with a 5mm shaft. Upsize the motor pinions and put it on Dual 70amp ESC's. Then I can play around with the Prop pitch and sizing to take advantage of all that torque. Should make for some neat water cooling modifications also.
On this E maxx setup, I'm going to see how the motor reacts to pulling that taller 2nd gear when I get the 2 speed installed. I'm sure it will do well. I will get some video's after I get the transmission upgraded.
Metalman said this motor looks small. You're not gonna believe how well it pushes this truck.
On 6S, I'm a little concerned about the Center Drive shafts being tough enough.
