01.19.2008, 05:00 PM
Originally Posted by speedy View Post
ok
So if put a neu 1515xxx motor in my e-maxx and run it on the same nuber of lipocells and gearing it will pull alot less amps and manage to get more rpm's to the wheels because of the tq of the neu ?how big difference in ampdraw will it be if i gear a neu with the same kv the same way as my feigao 8xl ? 20% ? less or more ?
It will draw slightly fewer amps in theory, but its more about efficiency. The feigaos are cheaply made motors, and waste alot of energy as heat, where-as the Neus are very well made and turn more of that energy into phyiscal power, in terms of wattage (both motors will draw the same current, but the neu will use it more efficiently). As a result you can gear the Neus a fair bit higher, and they will still run fairly cool compared to a feigao treated the same way. RPMs is simply relative to voltage and which motor KV you choose.
1515/1.5Y = 1500kv, good for 6s and the coolest setup.
1515/2.5D = 1700kv, good for 5/6s
1515/1Y = 2200kv, good for 4/5s
1515/1.5D = 2700kv, good for 4s, but the warmest setup.
By the way is there a better motor alternative than neu's ?
Depends what you mean by better. There are Lehner motors which are just as good as Neus, but they are 2 pole motors rather than 4pole, which means they will run better on all escs, but they are based in Germany, making them rare to find.
There are also the Plettenberg motors, which are 4 and 6 pole, but they tend to run warmer than the Neus since they have higher KV ratings, and they cost over $300. They are the sexiest looking motors though.
There are the Mega motor motors which are multi-pole inrunners, and they have massive torque, but the case design isnt the best for MT or car use.
And then there are the Align 600XL motors, which are a hybrid outrunner, with an inrunners case design. They are also massively powerful but tend to have a lowish KV rating making them better for high voltage applications, and some escs have trouble starting them, so gearing and programming has to be carefully tuned to avoid cogging.
EDIT: Prices vary, but:
Feigao XL = $60-90
Neu 1515 = $250-300
Pletty = $250-350
Megamotors = $150-200
Align = $150-200
