BashOn
02.14.2008, 11:14 AM
Originally Posted by fkadir View Post
Went for an initial run about 2 hours ago and got the same symptoms as you. The Motor will stop accelerating and cut out at about 1/2 throttle if i jab the throttle fast, I need to slowly accelerate for it not to cut off power. This is with using the flightpower 25C 5000mah battery so I dunt think quoality of battery packs should come into play.
seems like the cut-off algorithm is super sensitive or wrongly calibrated?
Yup, we had the same problem. Maybe MGM had a bad batch, even though we actually have different models.
I assume you were on cut off mode? Did you try reduce RPM?
