03.04.2008, 11:29 AM
Originally Posted by Peter Zicha View Post
Lincpimp I hope I didn't offend you..... the point I was trying to make was that if you can shoe horn the motors in they are great for the heavier models
Not at all Peter, you have more experience with the KB than I do! I have 3 of them, 10l, 8xl, and 10xl. I have not had a chance to run them in anything yet, but I have purchased a few 6mm bore pinions and removed the front endbell and tapped it for a conventional bolt pattern.
I need to get the Aftershock conversion started, as I intend to run the 10xl on 8s-10s thru a HV85 esc. The motor should be ideal for the heavy truck, just hope my lipos can keep up!
I originally thought that BOOGIE was using the rcm chassis, and there is very little space for batteries with a motor bigger than 36mm in diameter. Since he has the kershaw mount and access to machine equipment, I see no reason for him not to run the KB.
