G3R Spur/Pinion & Slipper Questions
thelav
G3R Spur/Pinion & Slipper Questions - 03.09.2008, 02:37 PM
Hi Guys,
I am relatively new here but I am in the process of building a G3R for racing. I have the hot bodies hardened diffs and will be using the G1 Single Speed Kit. Based on Mike's recommendations the plan is to also use a Neu 1515 1y on 4S lipos (8000mAh). I have used the speed calculator here but wanted to ask if I have all of the inputs correct. The values I entered are below:
Differential Ratio: 4.3
Transmission Ratio: 1.7222222222222223
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 24
Total Voltage: 14.8
Motor KV: 2200
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 130
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.13 : 1
Total Ratio: 15.73681 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 30844 RPM
Vehicle Speed: 33.82 mph (54.33 km/h)
Effective Speed Rate: 2.29 mph/V (3.67 kmh/V)
Estimated Adjusted Speed: 32 mph (52 km/h) - 4% loss
Effective KV Value: 2084.05
Motor Torque: 0.42 ft-lbs
Final Torque: 6.55 ft-lbs
Final Power: 1924 watts (2.6 HP)
Did I get the transmission ratio correct? I used the emaxx second gear selection because I figure that is what the single speed kit uses. I also used the OFNA 51T spur as I would like to keep everything Mod1. Tires were 40 Series (5.8" dia.).
I have not ordered the pinions or spur yet and want to make sure I am doing this right.
Also, if I go with the 51T Ofna Mod1 spur, what slippers can I choose from? From looking at the forum it looks like the Strobe or modifying something like the standard Revo slipper.
Thanks.
Mark
