Happywing
03.19.2008, 06:25 AM
So you have the latest firmware (1.17) loaded on your MM? If not, that upgrade will smooth it out. Is your motor direct-soldered to your ESC? That helps. The Feigao should run as smooth or smoother than a Neu. The Neu would run a lot cooler. If you want a Neu, why not wait for the MMM. That way you get motor and ESC for $300.
