Jammin
Jammin's Avatar
03.28.2008, 10:03 AM
The crt has buggy ratio diffs, 43/13. So he is way overgeared, with the 46/12. I have a crt and will upgrade it to the HB truggy diffs, 43/10, and run 46/13 primary gearing.. Stock spur on the crt is 62t. So changing back to that spur and running a 12t hardened pinion would do the same as the truggy diffs. Give that a try if you can, and see how it does!
It's a crt x1, not the buggy. Mike at rc monster told me that I was undergeard and needed a 16t pinion. Does that make sense. Oh and to answer the other questions, I do have a heat sink and the connections are perfect. Also the truck rolls fine. thanks guys
