sikeston34m
sikeston34m's Avatar
04.12.2008, 09:23 AM
Just so I understand correctly, with the castel link, by setting the cutoff v to 6v does that automatically transfer to the ccbec or is there another step that I am missing...before I plug everything in, I want to be 100% certain that I did not make a mistake.
Sounds like you need to go back and read the instructions again.
The Low Voltage Cutoff has nothing to do with the CC BEC at all. The ESC doesn't care what the CC BEC is doing, nor does the CC BEC care what the ESC is doing. They are two separate things.
The function of the CC BEC is to take the Receiver/Servo load away from the ESC.
You can not access the CC BEC setup through the ESC if that's what you are asking.
You have to plug the CC BEC into the Castle Link all by itself.
I was looking through the Castle Faq for anything that might help you. #25 in the list is pretty funny.
25. Is my CC BEC edible?
Please refrain from tasting the yummy goodness of the CC BEC. Castle Creations is not responsible for any cases of upset stomach, indigestion, or other GI malfunctions as a result of CC BEC consumption. Eating a CC BEC is known to cause cancer in the state of California.
