MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.27.2008, 07:39 PM
Depending on why they are stuck just use a bit of heat from a heat gun. Mine are normally stuck due to loctite and you just have to heat the pinion a little bit and she will pop right off. The motor will only get a little warm if you direct the heat at the pinion.
