david lamontagn
05.30.2008, 07:55 AM
Looks great! Are you using the RCM motor mount? How did you mount the steering and brake servo? I though the motor mount comes with a steering servo and receiver mount... did you just decide not to use it because of the mechanical brakes?
Thank's! yes i use RCM motor mount, but did not use the servo mount that came with the motor mount. I've put the steering servo direct on the stock RC8 servo post, and use Kyosho aluminium servo post to mount the brake servo.
And i don't like to see all the servos wires, so i've make a groove on the RCM batterie tray spacer plate and put all the servos wires on this groove and top it with the batterie tray.
This buggy is not so light because i use the 1515 motor, and a 5000mAh 4s pack, and the MGM controller is twice the weight of a MMM.
So it weight 8.3 lbs.
If i race alot this summer, i'll sell the 1515 and buy an 1512 1.5Y and change the 5000mAh 4s FlightPower for a 3200mAh, 5s.
For the run time, i realy don't know for now, and my gearing is 17/44 with stock mechanical brake.
