Associated T4 ?
rchippie
rchippie's Avatar
Associated T4 ? - 06.02.2008, 12:24 AM
As most of you know i have a t4 that i conveted to a J82. Im having a little issue ( in my opinion) trying to get the proper adjustment on the steering rod. I have the servo horn adjusted to one spline of center as it says in the manual. But when i make the steering rod the size it shows in the manual & connect it the wheels are pointing two the right. To correct this i adjusted the sub trim on my M8 to try & straighten out the wheels .I have to max out the sub trim to 15 on my radio. Does any one else have the same issue ?. Does any know in MM's how long the link should be ?. Thank's
REAL MEN RUN BRUSHLESS
