Your MM setup
Steve Krug
Steve Krug's Avatar
Your MM setup - 06.10.2008, 05:23 PM
Can I see your MM setups? What I mean is, if you guys are running 4S or 5S lipos in your MM, what are all the mods you do to it in order for it to work fine? Regaurding caps, BEC's, fans, etc.
One question also.
I just hooked up my CC BEC to the power wires and reciever, but whenever I punch the throttle, the reciever turns off, and regains connection a few seconds later. This doesn't happen when I do not run the CCBEC though. (Running 4S lipo by the way.) I also bolted a novak fan to the speedo, but when i run the CCBEC, the fan doesn't function.... Any ideas on this?
