RBMike
RBMike's Avatar
06.30.2008, 04:35 PM
The novak fan is a drop in replacment (except the wiring) but it will hit the fan cover & break as well. I found 4 small washers that fit inside the novak fan mounting holes. I put 1 in each hole (on the fans topside). Then put the fan inside the MMM fan cover. The washers space the fan father away from the cover keeping the blades from catching on the fan cover slots. As for the wire, I used the connector & wire that comes on the fan. Just run the wires out the side of the fan cover & plug into the RX in an unused slot.
