07.05.2008, 11:40 AM
I would go with a lower kv motor, and run 7s1p on the MMM. Something like the 1600kv 60mm medusa. High voltage will offset the 1p config, and the lower kv motor will run cooler.
4s2p a123 is just not enough voltage for a heavy vehicle, you current draw will be high, causing heat...
