TruckBasher
TruckBasher's Avatar
08.04.2008, 01:46 AM
Thanks Shaun, this Neu motors are really awesome as well as the A123 packs I got.
I didn't expect anyone to notice that about the tires..
Well, its a long story..first that spot was actually almost a mile away from my place not to mention half of it is climbing stairs and Im only pulling my truck on a trolley. The first time I hit the trigger (without knowing the power of the motor ) half and pulled it WOT bang....the CVD at the right rear was bent..it slipped out and stuck between upper arms and drive cup. Not sure how it happened..I walked a mile and Im not walking back without enjoying my truck...with a few bending skills I manage to put it back without removing anything but I noticed that when the arms is at the lowest position the ballhead of the CVD sits 1-2mm almost about to pop out. I pulled a Velcro strap and pulled both arms so they sit level and limit the downward travel so the ballhead sits farther inside the drive cup....this is similar to how joelings savage had the wires on the suspension arms...it held pretty well though I only had a few small jumps but at least I enjoyed the 30min run
I might be doing something permanent once I find a high tension cable like the ones used for climbing..(smaller dia of course)..
Truck is currently out of commission due to the lost pin of the CVD (not because it was bent )..might just get the rebuilt kit for MIP...
Jeff
E-Slayer direct drive to diff
