ptt81
08.05.2008, 09:33 PM
Not that I can see. As long as the voltage is equal or better than the originals, they were soldered correctly, and they are truly low-ESR types, it'll be fine.
Thanks Brian, yes im pretty sure all specs are better than originals, this is the one i used
http://www.digikey.com/scripts/DkSea...name=P12415-ND
I've just ran it today with Neu 1515 1Y and the temp at end of run after 15 min is about 145 on MM heasink and im geared 22/62, Neu got to 152 though, looks hot for Neu but i was told as long as I kept neu running below 175, it shouldn't be a problem. Would this be a safe setup to be continue running or do you suggest I gear down a bit? i was running 22/68 before but felt I want a bit faster. I also have a 1.5D comming, im wondering if I gear for 45mph, about the same as 22/62 on 1Y, would it make things run hotter or cooler? running strictly on 4s only
