09.06.2008, 12:04 PM
High power brushless does not allow reverse, but it uses more of the FETs at the same time; 18 instead of 6. So, the possible current is higher. The wiring is a bit of a PITA because you have to use all 3 wires to the motor - connector, and then wire the battery + directly to the motor +. If your motor doesn't need hundreds of amps, I wouldn't worry about it.
