TruckBasher
TruckBasher's Avatar
09.06.2008, 09:49 PM
Weird, you could switch it off and then back on and the lights would flash and beep, but when pulling the trigger it would completely die. I tried it with a rec pack and the red wire pulled and it worked for a few seconds. Is this the common BEC failure that everyone reports?
All the MMM with BEC issue started with this or either weak servo response then dies (except those that when into a great ball of fire)...I really think its not a IC failure rather than a design flaw...IC failure under load
E-Slayer direct drive to diff
