Definitive Post On Mmm Mods And Warranty
Bernie Wolfard
Clinically Inane
Bernie Wolfard's Avatar
Definitive Post On Mmm Mods And Warranty - 09.10.2008, 05:09 PM
PLEASE BE ADVISED, ANY MODIFICATIONS TO CIRCUIT BOARDS ON ANY CASTLE CREATIONS PRODUCT, WHETHER OR NOT THE ESC WORKS, VOIDS THE WARRANTY. IF A CASTLE CREATIONS ESC STOPS WORKING AND IT IS LESS THAN A YEAR OLD AND IT WANS'T ABUSED IT IS UNDER WARRANTY. IF THE ESC QUITS WORKING AND YOU MODIFY IT IT THE WARRANTY IS VOIDED. THE MOD SHOWN ON THIS THREAD PROBABLY WILL NOT WORK FOR MOST PEOPLE BECAUSE IT TAKES SPECIALIZED EQUIPMENT AND SKILL TO REMOVE COMPONENTS FROM OUR CIRCUIT BOARDS. WE USE LEAD FREE LIQUID FLUX HIGH TEMPRATUR SOLDER THAT DOES NOT WORK LIKE LEAD TIN FLUX CORE SOLDER. THIS MOD ONLY WORKS UNDER CERTAIN CIRCUMSTANCES AND IN MOST CASES ONLY DAMAGES THE BOARD OR LIFTS COMPONENTS ON THE OPPOSITE SIDE OF THE BOARD.
We are seeing problems with certain set ups with the MMM v2. Most (over 2400) work great with no problems. We cannot recreate these problems no matter what we do here to the ESC and its BEC. The failure points are not consistent and we are trying to track down what the problem is. Whatever this is, it will be fixed. If you want to help, and have not already done so, fill out Thomas’s request for information sticky on the forum.
A failed MMM will be repaired/replaced at no charge within one year from date of purchase. If there is any work on the circuit board or other obvious modifications, or there is crash damage, the ESC is out of warranty and will cost $70.00 for out of warranty replacement.
