TruckBasher
TruckBasher's Avatar
09.12.2008, 03:09 AM
Not sure what backfeeding the ESC while keeping the BEC intact will do. Depending on exactly what is bad (and how), it could basically short the external BECs voltage (which would send the external BEC into a cycling shutdown condition).
Back during my first mod, I was using an external BEC and didn't remove the red wire at first. Well, the KF voltage was ~6v, but the MMM BEC was ~5.5v and the KF heated up quite a bit. That tells me right there that the MMMBEC was heavily loading the external BEC because of the higher external voltage. So, even when everything is working normally, using an external BEC AND the internal one at the same time doesn't work.
This is what BrianG replied to me when I asked him about back feeding the MMM.
The main issue is that we dont know what is Dead on the MMM, if its the BEC then we might be able to revive it, since it is the same like removing the BEC unit, dead anyway...but if its a different component then we might kill other things...but the key is that the voltage regulator that feeds the brains must be something around 3.2v IIRC
E-Slayer direct drive to diff
