09.23.2008, 07:57 PM
Originally Posted by stum View Post
6000mAH is a lot of run time.. may even make it through a long a-main, 5k packs just make 20minutes tops.. the 6k packs should hold out I would think for a 30min a-main.
If a 5k pack does 20mins, a 6k pack will do 24mins...
Best to look for a pack that holds voltage better, it will have better runtime. I tested maxamps 5s 5k packs again an enerland 3700 25c 5s pack. No runtime difference, and a noticable increase in power from the enerland pack.
I would go for the Neu pack, it will perform better despite the spec. If you do buy the maxamps, the warranty is mandatory. You many also want to buy 2-4 maxamps packs, that way you should always have at least one that is not in the mail being returned...
