Shark413
Shark413's Avatar
10.03.2008, 03:31 AM
I am running the Tekno battery tray/straps and it is top notch. But may be it's just me. But I ran my brushless Slayer twice on the local track and I noticed some bend in the center support (it's pretty thin and designed to hold a relatively light fuel tank). See the first set of pictures, you can see how there is a gap between the tray and the middle brace, this is because the middle brace has bent downward slightly. Now I figured if you run a brace across the chassis using the carry handle holes (which are in the right place already) you could add a substantial brace with little effort. I took a 6061 bar of aluminum put a double bend in it, drilled a few holes, made a small spacer and then using the carry handle holes put in two M4 button head screws to hold it to the chassis. I just need to just add a heavy rubber pad under the tray area, clean up the ends and I am done. Actually you could retain the handle by threading the screws into the handle or for a super strong setup just use M4 nuts and discard the handle. Hey Tekno how about making a cool milled anodized brace, and I volunteer to test it for you.
This is the part that appears to be bending
With the tray bolted down front and rear, there is a small gap between the tray and the support on the middle brace.
Now using holes that are already in the chassis, marked by the arrows.
Take a bar of aluminum and put a double bend in it (one to clear the chassis and one to clear the motor brace)
Drill two holes that line up with the carry handle holes, make a small spacer.
Then bolt it down to the chassis, the piece that extends out under the tray can now be padded and will add extra support to the tray.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
