10.07.2008, 12:42 PM
As always a tough bunch to please but I think I can keep everyone happy (almost).
The revised pdf shows how it can work with using a simple tape measure however with the addition of the 3mm holes on the side of the vertical plate you can achieve a similar function to the Hudy setup.
However instead of expensive lexan and engraving you can use the rpm camper guage in the horizontal axis using the horizontal plate as the reference point against the vertical plate to measure toe!
This should work very easily - I added extra holes in the vertical plate for different cars. The only I need to review is the location of the holes in each plate to ensure:
1) chassis are not dragging on the ground.
2) provides enough vertical clearance over chassis and horizontal chassis clearance of shock towers for the horizontal brace to fit - Prior design didn't need to worry about this.
LMK what you think...
PS the first page shows how the calc works using tape measurements...
