sikeston34m
sikeston34m's Avatar
11.12.2008, 08:12 AM
Originally Posted by Maciolus View Post
I wonder how do you guys attach these outrunners to dogbones/CVD's?? Could you please give part number, etc.?
My answer for this was to use a stock transmission output shaft. They are 6mm in diameter. This does require chucking it up in a drill press or a lathe. All you have to do is knock off the center portion that engages the transmission output gear.
The result is a 6mm shaft that you install into the outrunner motor.
This allows factory length center drives to be used.
I hope this helps.
