"Long Shank Pinions" still too short
himalaya
himalaya's Avatar
"Long Shank Pinions" still too short - 12.05.2008, 03:38 AM
I have a Tekno Conversion Kit for 8-T. I prefer direct motor drive than the clutch. But I found my motor seems too far apart to the spur, even I have bought optional "long shank" pinions and "motor plate for long shank pinion". I have to pull the pinion out for a few mm to make the pinion have good couple to the spur, and thus the outter set screw(the one near the teeth) is completely loose, no use at all, only one set screw is actually tightenning the pinion to the motor shaft.
I tried Novak HVpro, Feigao XL, Align 600XL and many other motors, all the same, they use a standard shaft length of 16mm.
For stock mod 1 pinions from Robinson or Novak, no way, they are just too short to touch the spur!
So my questions are,
Is there any way I can move my motor a few mm closer to the spur?
Would Tekno have a "LONGER shank pinion" coming out for those using standard motors? or at least
Does Tekno recommend any other motors that have longer shaft ?
For future coming kits, would Tekno make more choices for customers to choose from? such as a kit includes NO clutch, and move the motor mount holes forward for 10~20mm so that I can use standard stock pinions.......
Thanx.
....What a Blue Sky....
