SeanZ0r
12.22.2008, 04:52 AM
Yo gee, Thats a cherry roller you picked up. This is going to be a pretty cool setup, I saw that exact write up in RCCA. I would run a 2s Lipo like 2000mah or w/e can fit to provide power for the start up system, and also solder a CC bec or similar to that to provide power to the eletronics so it's just one big battery that you have to charge. The CC Bec from castle will flash a red light, and more importantly shut off when the input voltage gets to the level that you set the output voltage to..So If you set it at 6.0v(what voltage a fresh receiver pack puts out) this will be a form of a cut off for your 2 cell lipo.
Did you see my brushless jato? It's worth it, but you already have a motor to be put in order, that will be balls out quick as well.
AE Factory Team TC4 4c2p 6000 & MM 5700
Brushless Traxxas Jato MM 5700
SH Z-Car MMM2200/5s4000mah Turnigy Packs
