petes66
01.08.2009, 09:38 PM
35-38mph according to novak, and I'd say that was about right really. In stock form the meaxx does about 30-31mph tops (before the titans fall to bits and the evx2 bursts into flames).
The only issue really is that a new hvmaxx pro 6.5 system costs about $300, and so does the MMM 2200kv system- given the choice... there is no choice, its a no-brainer really. I would say look on fleebay for a used hvmaxx system (older version with no lvc & the 3mm motor shaft), that'll cost closer to $150-170 and be better value for what you want really.
so the mmm 2200kv system is the mamba monster and you say its better then the novak? when you buy that system what else is needed or is it drop in rtr?
i dont mind dropping some coin for the right system, thats why iam doing my home work now. I have no clue when it comes to electric, like i said iam a rookie.
Also can you run brushless in wet conditions?
