Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
dangerwr
01.10.2009, 03:05 AM
The Ofna single speed spur setup uses the 51T spurs: http://www.rc-monster.com/proddetail.php?prod=ofn30110
Luckily, I happen to have a few from the old days when using an emaxx tranny with strobe slipper setup was common.
Note about the Ofna single speed kit: It does not come with support bearings or outdrive cups so you need to get those seperate. Also, my kit did not come with the needed grub screw, which is 5mm.
Ok. I am up to speed with the 51T spur--I will have to order one (or two!). As far as the center single-speed kit I installed that today (I will post pics soon). I used the center shaft from the 2-speed and seems to work fine--this way the bearings and out drives fit without issue. What is with the missing 5mm set screw?
Thanks for your help. Cheers!
