01.21.2009, 12:28 AM
Nice work linc! I'm considering sending you my Neu packs to re-wire. They come with 10ga wire that doesn't bend to well near the pack like needed in my E-REVO. Even after taking a dremel to the wire opening I still cut the insulation on the wire. For now I put the liquid electric tape over the cut, then wrapped with electric tape, and opened up the hole for them to pass through even more. I would also like hyperion taps, not a big fan of the kokam taps.
Sounds doable. Do you want 12 gauge wire installed? More flexible...
As for the tap swap that should be straight forward, getting the case open is usually the worst part. At least if you want it to close again!
And if it is anything like the trakpower or losi hardcase lipos, it could do with some extra cushion/packing in the case to stop the cells moving around.
