What????
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
What???? - 02.05.2009, 08:09 AM
Originally Posted by RevoKrazy View Post
I have my emaxx that has the old novak 4.5 hv and want to know what i have to do to make it work on 1 3s 5000 lipo or 2 2s 5000 lipos. it has the 2 deans connectors on it what do i do with the other wire for a 1single 3s 11.1 connect them together? Also do i need a bec and lipo cutoff?
First I would suggest doing a little foot work on your own by getting on line and looking up the ESC on the Novak website, and printing out the instructions for the Novak 4.5 HV Maxx, as this sounds like what you are asking about. That should pretty much tell you everything you need to know. Yes the ESC has dual wires for two batteries, so if you only install one that is fine. Just tie the other set of wires with its plug to something so it will not short out on anything. If you read all of the instructions that come with the ESC it tells you the specs and what batteries (1S, 2S, 3S, or whatever) you are able to run the sytem with. If you go on Tower Hobby and look up the ESC you can also find all of the pertinent information that you need there as well and print it up for future reference. Good luck with that.
SUPERMAXX YOUR LIFE.
