azjc
02.07.2009, 09:39 PM
Originally Posted by hemiblas View Post
If you guys think running a feigao with a fan is dangerous you should try running one without and see how long it lasts. Without the novak heatsink I added, the motor heats up pretty quick and the can does nothing to dissapate the heat. Even blowing air over the can didnt do much to help. I think we are all agreed, its a good beginner motor to get into the hobby to see what these things can do, but its not a long term solution.
one thing to remember about a motor is that the heat is generated in the interior and works its way outward (thermal dynamics) and when you blow cooler air onto the motor the cooler temp will not go beyond the edge of the hotter temp, so when you use a fan all you are doing is cooling the case and doing nothing for the rotor and magnets (the important parts of an electric motor)
