samwong
02.16.2009, 08:28 PM
Originally Posted by Countryhick View Post
Looks great!!! I think you might want a better quality motor. Maybe try a NEU??
Well done!!
Cheers Andrew
Thanks .. Andrew..
yes exactly ... I really need a serious motor... but in Hong Kong, it is hardly to find....finally yesteraday I got Losi Xcelorin 2100kv for my second trial.
And I will still keep the gear 19T p / 45T s and see how will the temperature of motor be...
May I know your motor spec (kv) and temperature after a continuous run? and how you compare 2gears system vs single gear system in 960 brushless conversion...in terms of motor temperature, acceleration and run time? as I still unsure if it need 2gears system for brushless... to achieve a comparable speed with other Gas Power 960. But seems now just use 2nd gear gives motor too much loading and temperature...( at least with cheap motor, hope Losi 2100kv works better)
