Pdelcast
Pdelcast's Avatar
02.24.2009, 02:47 PM
Originally Posted by Jabe View Post
Ill like to protect my controllers, so i was thinking about adding this little component and capacitor parrel to my battery connectors, to protect esc from voltage peaks and drops.
Im using batterys that should power my system in theory, 240A (in theory) continous should be enough.
What castle has to say about that? Would it be good idea?
Already a TVS on the Mamba Monster. The TVS on the Monster is rated for over 2000A -- but it's the total power that is the limitation. You can't put a thousand watts into a 1 gram device and expect it to survive more than a few thousandths of a second. We are talking SERIOUS power here. The Mamba main FETs themselves can stand about 12000A of avalanche current -- but that's instantaneous current again. For four seconds of normal braking power (if the battery refused to take the power back) you can expect about 2000-8000 watt seconds of power that needs to be dissipated. There IS silicon that will take that kind of power -- but the chips are the size of hockey pucks.
Patrick del Castillo
President, Principle Engineer
