tom255
tom255's Avatar
02.25.2009, 01:27 AM
Originally Posted by teknorc View Post
The motor is still using power to stop. In other words, ESC braking is not free. The 'regenerative' part is that it can recapture small (if not tiny) amounts of power in between the pulses while the braking power is applied. After all, a force is essentially being applied in the opposite direction to bring the car to a stop, just as it would if it was starting from a standstill. This is also why motor brake setups run hotter since the motor is working in both directions. Also, braking force is usually applied more abruptly than while accelerating. AFAIK, a single mechanism (the motor) can't function as a generator and a source of power at the same time. You must use power to brake the car. I'm not an electrical engineer, but I know a few things about physics and the forces that are present and being applied in this scenario simply can't be ignored.
Please correct me if I'm wrong here because our results coincide with jhautz and others that have found mechanical brakes to be more efficient. I'm not arguing that some energy isn't being harnessed or regenerated while braking, I'm saying that it does in fact use power to brake and that the overall net of the system is negative, not positive. Mechanical brakes are obviously using power as well (servo), but compare a servo's energy requirements to a 1/8th brushless motor's requirements and I think the picture becomes clearer.
Actualy Its consume very little not more than couple amps! One guy in russian forum made tests about regenerative brakeng and he did not recorded any noticable power consumption its just shorting motor windings and power force applies through shorting Impulse lenght and opposite phase switching, power consume mostly for FET drivers, brains then braking. MGM, MMM, MM, Schulze, Quark B125. No one regenerated a power, all regenerated power goes for FET heating.
