BitHed
03.11.2009, 09:08 PM
...thanks for the post Crazy :D
...I hadnt thought about the HF arm until you mentioned it but i will have a look at it...Sounds easy...
...one of the lower holes on the HF tower matches the tierod hole on the Savage bulk...I made the 3mm hole a 4mm hole and just put a bolt through...
...The UPPER pins protude a little bit which means this lower bolt that i put through needs about 4mm of spacers so the tower fits flush...Easier to see with pics that i will have to put up...Really very easy though once you see it :D
...Other than that i just drilled those two new holes in the tower to screw it to the bulkhead at the top...Check out the labelled pictures...You can see the 4x50 bolt i put in...
