Overkill
Tried Nitro.............Once!!! !!!!
Overkill's Avatar
03.18.2009, 02:26 PM
Originally Posted by azjc View Post
whats the kv of the motor....if its the 2200 with 5s your temps are what I would expect, I have the same 8T but I have a Neu 1515/2.5d with 6s. I have a flightpower 6s 5000 and a Zippy 6s 4150 packs that I run and geared 48/16
Yeah it is the 2200, I thought it may run around the 130 mark on the ESC, I am going to try a 12t pinion and see how that goes on the 5s and use a 14t pinion on the 4s. When I have read all the probs that have come with the MMM, one of the common factors is heat so I want to run a cooler setting to get the most out of my investment..............well, that's what I am going for
The intial trial by error and temps is actually not that hard at all, considering the amount of mucking around I would do just to get my nitro in the sweet spot before a play and that took me at least 2 gallon before I was any "good" at tuning. Just need to get a couple more batteries so I can stay out longer and test all areas till I get my happy setup
azjc.......What are the temps you are running on the setup/MMM with it geared for 49MPH, while you are out having a bash?
I like it.......I LIKE IT ALOT!!!!!!
