rchippie
rchippie's Avatar
03.18.2009, 10:41 PM
Originally Posted by RCShocker View Post
You should be able to use stock rod ends and your stock uppers w/ that chassis. The upper's may or may not be the length you need though.
The KK lowers will needs rod end's installed unless you can talk Jeff into doing that. Well worth it.
I used some oversized HPI rod ends and didnt really like them. The Revo "pushrod" ends that go to the rockers would probably work best though.
Are you considering the high or medium clearance delrin lowers?
Jeff suggested i might like the HC links , since i wont be competing . Are the revo rod ends the same size as the stock rod ends ?.
REAL MEN RUN BRUSHLESS
