tkhoo
04.06.2009, 09:54 PM
If you use an external 6v battery pack this is doing the same job as a bec (so no external bex required)...
Remember to remove the red wire from MM to RX though if using a battery pack or bec.
Thanks Arct1k.
Hi AJrc, may I know your combo MM+Feigao 9L do have any cogging problem when slow moving? What your run time with what capacity of the Lipo on how many S? What tooth the pinion you run with it? Thanks.
