04.13.2009, 05:28 PM
Originally Posted by scarletboa View Post
what do you have against fans in r/c vehicles? is it because they get messed up when bashing or racing in dirt?
That's one reason, but I'll list them all:
1: Short lifespan due to dirt/debris and environment.
2: Added wiring complexity.
3: Shorter runtime and more weight (albeit not much).
4: Poor subsitute for a proper motor/ESC. If things get hot where you need a fan to remain operational, chances are there is something wrong with the setup (needs larger motor and/or ESC, or different gearing).
5: If you rely on the fan to keep temps in check, what happens when it fails and you don't realize it? 'Cause you know it will fail...
However, if you have a good setup that runs just warm under normal use, and just use fans for extra cooling, that's ok I guess. I just like simple, and additional fans goes against that.
