04.22.2009, 12:44 AM
So you guys think it is safe to use the micro deans and leave the internal battery in place? Paralleling different mah cells is generally not such a good idea, as the lower mah cell will generally discharge at the same rate as the higher mah cells... I will have to figure out some sort of switch...
Using the charge port isolates the draw to the internal battery (I assume) and allows the external source (another battery in my case) to recharge the internal battery... I will try both ways.
