05.28.2009, 05:05 PM
Originally Posted by superek4 View Post
Hi Brian,
So if I m not wrong u r saying 6s 5000 will last longer than 4s 5000?
I m running a x2 CRT with 50slip diff n 12pinion, medusa 2000kv motor n watever batt that will last 30mins or more
If you have those batts running different kv motors that both end up spinning the same max rpm and the same gearing on each the 6s pack should give you half as much time again, say 30 mins vs 20 mins on the 4s. You have half as much voltage again with the 6s compared to the 4s.
A 1500-1600kv motor would be the best bet, along with a 5-6k mah 6s lipo. That will yield the longest runtime to the lightest weight. Plus you could get away with a 25c rated packs for track speed, that will also help with weigh/size as the higher c rated cells tend to be a little heavier/larger.
