Finnster
KillaHurtz
Finnster's Avatar
06.08.2009, 11:50 PM
Sweet, did you not have to trim the box for that battery?
Can you take a look at the above post?
That was a 7" box, fits the 165mm Neu tight. I have some shorter but wider zippies as well, so I made the box 50mm inside so it fits both. This would be about the most universal size.
The Zips then have about 15mm space on the ends. Hard foam blocks fills in and cushions nicely. The above posts should explain things nicely, but if there are any more Q's I'll LYK.
