kalbien
06.26.2009, 05:06 AM
Well I don't understand what you are asking here..
you run 2200kv motor with gearing that is way too fast even with 4s. Than you put 5s to the system, made you motor run over 40k RPM and than you are surprised that it was hot..
Use that calculator that is alfa & omega for all of us. Gear it to 60km/h maximum and you will be just fine. For 4s that is 13/14 pinion in your case. Don't run 5s in 2200kv motor ever again and you will be just fine.
