1/16 E-Revo w/ Mamba Max and Neu 1112 Finished!
BP-Revo
BMW M Power!
BP-Revo's Avatar
1/16 E-Revo w/ Mamba Max and Neu 1112 Finished! - 07.01.2009, 02:52 AM
I finally finished it tonight.
It's not 100% done, but it's just about there (it's driveable now, at least).
I still need to receive and add in the aluminum toe links and pushrods. Aluminum hexes arrive tomorrow and will be added in.
Tonight I rebuilt the shocks using the Traxxas TiNi shafts and Aluminum bodies with 50w oil with tan springs front and black springs rear (tan is 1 step stiffer than stock green, black is 1 step stiffer than tan).
Also threw in a Spektrum SR3500 micro receiver.
Previous nights work involved ripping out all the stock electronics and selling them (the only stock thing left is the servo, and by its performance it wont be in there too long).
I also had to cut down the shaft on the 1112 (was too long and hitting motor plate), grind a flat spot, and trim the rear shock tower for clearance.
Had to get rid of the sealed receiver box (put Mamba Max ESC in it's place). Put Castle BEC on the unused steering servo mount cover plate.
Also glued up a set of HoleShot LP 1/10 Buggy tires on OFNA CRT .5 wheels. However, the CRT.5's have much longer axles and deeper hexes which caused problems so I had to dremel some material away from the back of the rim and replace the stock locknuts with regular old nuts which will need to be loctited on. The tires are slightly (about .1 or .2 inches) larger than the stock talons, but are only about 2/3 as wide. It gave it a much racier stance.
Right now it has the 23T 'speed pinion' which was included with the truck and first (and only) 3 minute test run was done on 3S2P Crapamps 1100mah packs from my friend's airsoft gun. It is plenty fast but has too much torque (wheelies all over the place with anything more than 1/2 throttle even at ~20mph). Should have probably used an 1110 (might get on and swap it out down the line), but I got the 1112 at the right price. I'll probably end up gearing up and just running 2S. The packs I have on order are Zippy 2S 2200mah (so it'll run forever on 2P, being 4400mah total). If wheelies are still a problem I'll likely put some sort of weight up front.
I know there are no pictures, but I have no idea what my parents did with the camera. But I'll try to get some by the end of tomorrow.
But first impressions is that this will be a very fun truck.
