nitrostarter
nitrostarter's Avatar
07.03.2009, 01:32 AM
Originally Posted by gimpygolden View Post
....All the guys over at Offshoreelectrics.com seem a little spooked at the idea of High Volt setups so I wanted the opinions of those more versed in big power setups.
Honestly, I highly doubt this is the case. Most guys there run boats that are setup to spec. N, P, Q classes, etc... They are listed as to which battery setups are used.
Have a look at this chart:
http://www.castlecreations.com/suppo..._boat_apps.pdf
This is a helpful tool for boating.
Honestly, I don't think A123's are worth there salt in boats... Most setups require high quality Lipo cells as boats can pull SIGNIFICANTLY more amps than the car world. For instance, most people that run 1515/1Y use a Hydra 240 because the amps spike up pretty high continuously. Its also very easy to use the wrong prop and burn up something in a heart beat.
Also, most FE boating setups only get 3-7 minutes of runtime. I would want to most mAh available.
Now on to your setup...
Aeromarine Titan 29, a beautiful mono with the ability to take a decent chop. In order to make boats work properly, you want to spin 28-33k rpm's. SO if you're insisting on pushing a 850kv motor, 10s will be necessary.
Honestly speaking tho I would opt for the 5s2p setup for not only more available amperage, but more than likely, more runtime.
Motor choice: The KB45 1700kv would be a great choice, KB's seem to be a hard to beat motor in boats when properly used. However, a Feigao 11XL would work just as well in this hull. This 29" hull doesn't really require more than a feigao 9XL for power. A 10XL would be optimal.
I don't know your asperations for the boat but for anything over 30mph I would run a Feigao 11XL on 5s2p, with a X445 prop. Should be a reliable setup with those A123's being the weakpoint...
Enjoy.
N. Rustler conversion
