NoControl
NoControl's Avatar
07.10.2009, 11:38 AM
I skipped most of all the posts, so heres my take on it, in the electronics industry ( as far as I know) most companys try to make wires, traces, and whatever else any kind of signal travels threw ASAP to reduce EMI (Electro-mag-interference) which long conductors do fantaasticly good at at picking up EMI, think of a long wire or trace on a circuit board like an antenna, it'll pick up a lot of crap signals that you DON"T want, and the other side of it is, every condutor has a resistance, resistance robs power, in most cases the resistance is so small that its barely even measurable but once you get enough then you start losing power and making heat, and in a wires case I beilieve it has a positive temp coefficent (might be negative) where as the wires temp goes up so does the resistance not by alot but in the end it just keeps reducing the power that goes to your motor..
Hope most of thats correct and hopefully I didn't confuse anyone.
E-revo MMM 2200 6s zippy 50MPH of pure fun and parts destroying powa!
Futaba 3pk more controller then anyone person needs
TC5 top speed drifter 21mph on crappacks and 40 on calc
