iTz Nicholas
Talking 07.13.2009, 04:45 PM
Originally Posted by Snipin_Willy View Post
The biggest concern I have with bullet connectors as battery connection is that even if you heat shrink them they will never be as safe from shorting as deans/trx plugs. Only way to solve this is to find some type of plastic casing that the bullet plugs fit into, similar to the HC Turnigy packs
All you have to do it put one male and one female on the battery and vise versa for the ESC. You would have to be careful when you are storing them tough because something could bridge the gap and poof...
I'm getting some Hyperion bullet plugs because if you wanted you could easily run a series or parallel setup.
"You can kill the revolutionary, but you can't kill the revolution." - Fred Hampton
"The common people suffer when the powerful disagree." - Phaedrus
